Segmented Table
The Segmented Table component displays one or more data tables grouped under an optional section title. Each table can have its own subtitle, allowing related data to be presented in clearly separated segments on a single page section.
Overview​
This component is useful for presenting structured technical data — such as machine specifications or comparison charts — in a clean, consistent layout. Each segment is an independent table with its own optional heading.
  1. Section Title (optional) — A heading displayed above all the tables in this component.
  2. Tables (required, minimum 1) — A repeatable list of table segments. Each segment has:
    • Segment Title (optional) — A sub-heading displayed above the individual table.
    • Table Data (required) — The table content, entered via the table editor. The table is composed of:
      • Columns — Define the column headers and their types.
      • Rows — The data rows, one per entry.
    You can add as many segments as needed. Each segment is separated visually on the page, making it easy to group related data (e.g. "Standard Options" and "Optional Extras") within the same component.
