Add, Edit, and Remove Resources
This guide provides step-by-step instructions for adding, editing, and removing resource entries in the Hurco Backoffice. Managing these entries keeps your website's Resources section up-to-date and relevant.
Adding a Resource Entry​
1. Navigate to Content Manager​
2. Select Resource Type​
Click "Testimonial" or any other Resource type you want to add an entry to.
3. Create New Entry​
Click "Create new entry".
4. Fill in Resource Details​
Complete all required fields for the resource entry, such as:
  • Title
  • Featured Image
  • Category
  • Resource Date
  • Resource Author
  • Resource Text
  • Resource Media
  • Resource CTA
For details on each field, see Resource Fields Explained.
5. Publish or Save​
Click "Publish" to make the entry live, or "Save" to keep it as a draft.
Editing a Resource Entry​
1. Select Entry to Edit​
Click the entry you want to edit (e.g., "The Marvels of Multi-Axis Machining").
2. Update Fields​
Edit the necessary information in the fields.
3. Publish Changes​
Click "Publish" to update the entry.
Removing a Resource Entry​
1. Open Options Menu​
On the resource entry you want to delete, click the 3 dots icon to open the options menu.
2. Delete Entry​
Click "Delete entry (all locales)".
3. Confirm Deletion​
Click "Confirm".
info
  • Publishing a new resource entry, or changes to an existing resource entry, will make them live on the website immediately. Saving will keep them as a draft that is not visible to website visitors until published.
  • Deleting a resource entry will remove it from the website immediately. Always double-check before deleting. This action cannot be undone.
